1993 Nissan Altima Speedometer Stuck
ALTIMAMAN
my speedometer, moves up fast to 40mph and stays at 40. when I reduce speed it moves down slowly but not to zero until the ignition is turned off. what could the problem be? 1993 nissan altima with 266,000 miles 2.5L
Jul 21, 2007 at 9:47 AM
  • 75,988 POSTS
[quote:4d0098a694="altimaman"]my speedometer, moves up fast to 40mph and stays at 40. when I reduce speed it moves down slowly but not to zero until the ignition is turned off. what could the problem be? 1993 nissan altima with 266,000 miles 2.5L[/quote:4d0098a694]
Check the vehicle speed sensor on the tranny.
Jul 21, 2007 at 1:16 PM
Suggested Repair
Check the vehicle speed sensor on the transmission.
Conversation Summary
The owner of a 1993 Nissan Altima with 266,000 miles reports the speedometer jumps quickly to 40 mph and stays there, then drops slowly when speed is reduced but does not return to zero until the ignition is turned off. The expert recommends checking the vehicle speed sensor on the transmission.
