1998 Nissan Altima Engine Knock
ERICKAD
My 1998 Nissan Altima SE with about 125,000 has a very noticeable but small knocking sound coming from the engine, especially when the car is sitting still, like at stop lights and in the drive-thru. It isn't a clanking just a small knocking. I had someone take it in to the dealer (big mistake) on Monday to get rid of the knocking. I work during the day. They charged me for "Steering/Suspension by replacing left and right front sway bar links and replacing left and right front acle (I think they meant axle) boots. They charged me also for repair kit, rod assy-connec, nut, washer-special, bushing-rubber and bolt". I drove the car on yesterday, Tuesday, and it is still knocking. I am definitely going take it back. I spent hundreds of dollars for this work and feel like they didn't even fix the problem, but charged me for things that didn't fix the problem. What could be the problem and what is the best solution for dealing with the dealer? This is my first bad experience with them. This might be the last time I go to them.
May 17, 2006 at 3:58 AM
LOSONE
  • 1,616 POSTS
There must be more dummies per cubic yard at that dealer-ship than anywhere else I have seen.
Anyone knows a front end can't knock sitting still. First determine if the knock is from the valve cover area, the bottom of the engine or the timing belt area. Take a long screwdriver and use it as a listening device by putting the handle in your ear and the metal on the suspected knock area.
May 17, 2006 at 4:38 AM
Suggested Repair
Do not replace more front-end parts for a knock heard while the car is stopped. Use a long screwdriver or mechanic's stethoscope to locate the noise at the valve cover, lower engine, or timing belt area, then repair the identified source.
Conversation Summary
A 1998 Nissan Altima with about 125,000 miles has a small engine knock, especially while stopped. The dealer replaced front sway bar links and axle boots, but the knock remained. The expert said stationary knocking cannot come from the front end and advised pinpointing whether it is at the valve cover, bottom of the engine, or timing belt before further repairs.
