Nissan Altima 96 - How to replace windshield fluid dispenser
CANLASJP
I got a Nissan Altima 96 with 90K miles. My windshield fluid dispenser is leaking fluid. The dispenser seems not easily accessible. Any ideas how to get into it ? Can I glue it if the crack is not too big ? If so, what type of epoxy ?
Thanks in advance.
Jul 15, 2007 at 2:19 PM
1PONYBEAST
[quote:8f507af73f="canlasjp"]I got a Nissan Altima 96 with 90K miles. My windshield fluid dispenser is leaking fluid. The dispenser seems not easily accessible. Any ideas how to get into it ? Can I glue it if the crack is not too big ? If so, what type of epoxy ?
Thanks in advance.[/quote:8f507af73f]
take the front passenger side wheel and splash shield, and you will see the canister/resovour in there, there's two bolts you need to unscrew, but before you do that, you will need to drain the fluid first, since you will have to take the hose off...
Sep 13, 2007 at 5:05 PM
