2008 Nissan Altima Hybrid starting my hybrid
37,865 MILES • 4 CYL • FWD • AUTOMATIC
SHAMROCK_ROSCOE
when i push the ignition button the car keeps telling me to push the brake. everything on the car turns on like normal but when i engage the gear shifter to a gear nothing happens. again, the light is telling me push the brake like i need to start the engine.
Mar 12, 2010 at 10:42 PM
DAVE H
  • 13,383 POSTS
Hello .. thanks for the donation .. much appreciated You really need to return the vehicle to the dealer to be repaired under the warrenty .. sounds like the fault may be in the HVC (Hybrid Vehicle Control) ECU .. it will have to be plugged into the nissan Consult III diagnostic scanner to locate the actual cause of the fault ! Hope this helps
https://images.2carpros.com/forum/automotive_pictures/266999_AAA2_1061.png
Mar 15, 2010 at 11:03 AM
