Nissan Altima
NISSAN ALTIMA
INEZ
I have a 1996 Nissan Altima. About a month ago it started blowing the fuse that controls the dash board monitors. (speed, gas,oil light...etc) Then my left head light blew. I replaced it with a new one and it stopped blowing the fuse for the dash board. Well, about 3 weeks later i got in it, started to crank it and it would turn over but would not start. Later that day i tried again and it started. As i was driving down the road the motor started trying to turn off. NOTE* it only does this when the motor warms up. Plus sometimes it will or will not crank. I have purchased and replaced the coil, coil wire and all fuses. Could you pleaseeeee tell me what you think the problem is? [/b]
May 21, 2006 at 6:29 PM
FARVAS
that sounds like a shaved wire harnes that is shorting out when it moves a certen way i had a similer problm with a 96 neon it turn out to be a rat eat part of the harnes so
check for wires that may be rubing together hope this helps
May 28, 2006 at 1:25 AM
