[quote:4195281f16="rasmataz"][quote:4195281f16="randomorbit3"]Dear rasmataz,
Thank You for your response about my problem.
Please note all other posts that I have included with this problem. I think you will see that all of the bases that you mentioned have all ready been covered and then some. Yes, it is going into closed loop as well. Egr system checked as well. The spark is blue-white and the coil, pick-up, module and CPU have been checked as well. My scanner is a Snap On Modus.
Any more ideas??
Thanks,
Fred[/quote:4195281f16]
Fred-I'm convinced its fuel related problem.Try rechecking the injector for no.3. you got me going on this-its a mind breaker.am thinking of fuel injection duration-but not so sure were dealing with one cylinder,/fuel trimmings/reflashing.
If resistance is not within specifications (typically 3 to 5 ohms for a low-resistance injector, or 12 to 17 ohms for a high-resistance injector), the injector needs to be replaced. A difference of only 1 ohm less than specifications may be enough to prevent the injector from opening reliably under some operating conditions.
Note: Injector resistance typically increases a couple of ohms as it warms up. Therefore, you should check the values twice: Once when cold and once at normal operating temperature. If resistance goes out of specifications when hot or cold, replace the injector
I'll find some more and get back to you
Good Luck[/quote:4195281f16]
May 29, 2007 at 12:10 AM
