Driver Side Window Problem (1999)
SHSTAR50
  • 8 POSTS
My Nissan Altima, GXE, 120K mileage, 2.4 engine has an intermitant problem with the driver side window going UP only. It goes down without a problem. I'm guessing I need that module replaced, which is easy enough. Am I correct in my assumption??
Thank You!
D. Hernandez
Oct 2, 2007 at 5:26 AM
FISHERMAN
  • 937 POSTS
[quote:8ac50cd9eb="shstar50"]My Nissan Altima, GXE, 120K mileage, 2.4 engine has an intermitant problem with the driver side window going UP only. It goes down without a problem. I'm guessing I need that module replaced, which is easy enough. Am I correct in my assumption??
Thank You!
D. Hernandez[/quote:8ac50cd9eb]
Usually the driver side window "works" more than the pass. side..
if you have trouble going "up" its because its harder for the motor than going "down" sometimes the electric motors get "weak" and they have a "disconnect" resistor that kills the current when its all the way up... To prevent force the motor and burn it out..
first check your switch if its good the motor its your second option...
Oct 3, 2007 at 12:51 PM
SHSTAR50
  • 8 POSTS
[quote:879bdfd8bf="fisherman"][quote:879bdfd8bf="shstar50"]My Nissan Altima, GXE, 120K mileage, 2.4 engine has an intermitant problem with the driver side window going UP only. It goes down without a problem. I'm guessing I need that module replaced, which is easy enough. Am I correct in my assumption??
Thank You!
D. Hernandez[/quote:879bdfd8bf]
first check your switch if its good the motor its your second option...[/quote:879bdfd8bf]
Thank you for your help! I will send a donation as soon as I can; I think you guys really deserve it! I will check the switch. That part is expensive..I can only imagine what a motor costs!!
Oct 3, 2007 at 1:17 PM
FISHERMAN
  • 937 POSTS
Hopefully its just a false contact on the switch...
Good luck!
Oct 3, 2007 at 1:46 PM
SHSTAR50
  • 8 POSTS
[quote:b76e5c3121="fisherman"]Hopefully its just a false contact on the switch...
Good luck![/quote:b76e5c3121]
Thanks much! I'll report my findings! Might not be very soon, though...but I'll be back!
Oct 3, 2007 at 2:05 PM
