Bad gasoline
BRYAN MORRIS
My 2001 Nissan Ultima, 4 cylinder, 94,000 miles has had approximately $2,200.00 worth of engine work since July 13th, 2007 when I filled up with gasoline and could barely make it out of the station's parking lot. The Nissan service specialist said we had gotten VERY BAD gasoline and referenced it as "swamp water." He put a sample of it in bottle for us in case we wanted to get it tested. My first question is: "where could we get it tested?" My second question is this: "Is all the work they've done on it since July 13th, 2007 interelated with the bad gasoline??" Work/Replacements on July 14, 2007 are as follows: 1) 2 engine drive belts; 2) EFI Consult Diag & R&R Fuel Tank/CL, Packing-Fuel GA; 3) Fuel Filter; 4) Fuel Injector Service; 5) Spark Plugs; 6) Oil Change. Work/Replacements on August 21, 2007 were done as a result of "Check Engine Light" that didn't resolve itself after 5 days: 1) Engine Performance Diagnosis; 2) Catalysts and Gaskets, 3-Way Catal, Cap Converter; 3) Knock Sensor, Sensor Assy-Kno; 4) Air Flow Meter and Air Filter, Volume Air Flow, Element Assy-AI
I would so appreciate a detailed response "in kind."
Thank so much!!
Aug 25, 2007 at 6:06 AM
  • 75,988 POSTS
[quote="Bryan Morris"]My 2001 Nissan Ultima, 4 cylinder, 94,000 miles has had approximately $2,200.00 worth of engine work since July 13th, 2007 when I filled up with gasoline and could barely make it out of the station's parking lot. The Nissan service specialist said we had gotten VERY BAD gasoline and referenced it as "swamp water." He put a sample of it in bottle for us in case we wanted to get it tested. My first question is: "where could we get it tested?" My second question is this: "Is all the work they've done on it since July 13th, 2007 interelated with the bad gasoline??" Work/Replacements on July 14, 2007 are as follows: 1) 2 engine drive belts; 2) EFI Consult Diag & R&R Fuel Tank/CL, Packing-Fuel GA; 3) Fuel Filter; 4) Fuel Injector Service; 5) Spark Plugs; 6) Oil Change. Work/Replacements on August 21, 2007 were done as a result of "Check Engine Light" that didn't resolve itself after 5 days: 1) Engine Performance Diagnosis; 2) Catalysts and Gaskets, 3-Way Catal, Cap Converter; 3) Knock Sensor, Sensor Assy-Kno; 4) Air Flow Meter and Air Filter, Volume Air Flow, Element Assy-AI
Thank so much!![/quote
CEL what was the code/s ?
If its a bad gasoline it should be throwing a random misfires every cylinders are being affected.
Aug 25, 2007 at 9:40 AM
SERVICE WRITER
  • 9,123 POSTS
Although maybe too late now, it should have brought to the gas station’s managements attention, You should not have been the only one that this would have happened to.
1) 2 engine drive belts; (no relation what-so-ever)
2) EFI Consult Diag & R&R Fuel Tank/CL(related), Packing-Fuel GA (not sure what this is saying)
3) Fuel Filter (related)
4) Fuel Injector Service ( not related) This could have been easily flushed with regular gasoline
5) Spark Plugs (a good idea, may have been avoidable, but if they are out no sense in putting them back unless they are reasonably new.
6) Oil Change ( a good idea) When the engine is cranking and not igniting fuel is probably getting into the crankcase.
Like Raz says need to know what code(s) were in there for the August visit. Were there any problems between the two visits other than the CEL being on?
Aug 25, 2007 at 11:38 AM
