Altima 05 excelaration
SHUMON2000
I found sometime my altima 05 (64000 mile) does not accelerate very well from stop and go scenarios and sometime gas paddle seems harder. What could be the possible reason(s)? I would appreciate your suggestions. Thanks.
Aug 9, 2007 at 9:04 AM
2CARPRO JACK
  • 11,533 POSTS
Is your car drive by wire? ( no throttle cable) If so then the TPS on the pedal might be going bad and causing a stiff pedal. If not then look for any obstructions near the pedal and try working the throttle by hand to see if it the problem (engine off)
Aug 9, 2007 at 9:46 AM
