2008 Nissan Altima Making a whining/grinding noise
DEE GARLETTS
Noises problem
2008 Nissan Altima Automatic 24460 miles
My car is a 2008 Nissan Altima 2.5S with a CVT (variable) automatic transmission. I have never used the manual function on the transmission. The engine is making a noise when I accelerate, something between a whining and a grinding noise. The noise goes on at all speeds, and stops when I take my foot off the gas. It sounds like the transmission might be trying to shift, but I'm not sure. The engine temperature does not go up beyond the normal range.
Mar 17, 2010 at 4:45 AM
MERLIN2021
  • 17,250 POSTS
Is this still under the warranty? Also there is a know problem with the tranny cooler hose clamp, I will send you the info via email.
Mar 17, 2010 at 8:40 AM
DEE GARLETTS
The car is still under warranty. I received the bulletin you sent with instructions about the Service Campaign. Thank you for your help.
D
Mar 17, 2010 at 10:06 AM
MERLIN2021
  • 17,250 POSTS
OK keep me updated if you want!
Mar 18, 2010 at 8:28 AM
