1998 Nissan Altima Loud Whine When Turning Sharply
1998 NISSAN ALTIMA
JARICKETTS
Noises problem
1998 Nissan Altima Front Wheel Drive Automatic 160000 miles
My 1998 Nissan Altima has started making a loud whining sound when I turn the wheel sharply. The sound only starts when I turn it sharply, and then it never goes away and gets louder with acceleration. Soft turns do not cause the sound to start, only sharp turns.
Does this sound like a power steering pump issue, and if so about how much would that cost to repair? Could it possibly be just fluid levels?
Thanks!
Dec 23, 2009 at 2:37 AM
  • 31,937 POSTS
Hi there, check that the fluid is ok and that the belt is tensioned correctly, failing this i feel it will be a pump issue, costs will vary depending on where you get this work done, best you contact a mechanic in your area for a quota as i am in Australia any my pricing will not be very relevant.
Mark (mhpautos)
Dec 23, 2009 at 12:19 PM
JARICKETTS
Checked fluid levels and it was bone dry! Just had all topped off last month so I knew there had to be a leak. Thankfully it was just a hose-relatively cheap and easy fix at the shop. Now she sounds great!
Dec 23, 2009 at 2:34 PM
  • 31,937 POSTS
Thats good to hear, thank you for the feedback,
have a great Xmas and new year.
mark.
Dec 23, 2009 at 2:37 PM
