2007 Nissan Altima no gear response
10,000 MILES • 4 CYL • 2WD • AUTOMATIC
EPLATINUM23
hello. 2007 altima won't take gears even after refilling empty fluid reservoir, checking for leaks and 15 minutes of trying to get a gear to respond...please assist with possible solution.
Feb 25, 2009 at 2:57 PM
  • 31,937 POSTS
Hi there,
When you say you re filled the fluid reservoir, do you mean the transmission oil was very low? Is the level correct now? have you used the correct type of transmission oil? If yes to all these and you have no drive at all, i would suggest a tow to a transmission specialist for a test and report as the problem may be a serious internal failure.
Mark (mhpautos)
Feb 25, 2009 at 4:01 PM
