2005 Nissan Altima Vibration
150,000 MILES • 6 CYL • FWD • MANUAL
OL2LRUS
  • 5 POSTS
While highway driving at 70MPH I experienced a vibration, like a washboard in the highway. When I touched the brakes to slow down a little the vibration disappeared. This has happened a few times. The vibration is felt through the whole car, not necessarily back thru the steering.
Mar 22, 2010 at 4:29 AM
DOCFIXIT
  • 18,828 POSTS
Possible faulty struts have fronts and rears ever been replaced?
Mar 22, 2010 at 4:42 AM
OL2LRUS
  • 5 POSTS
[quote:bc3741eb84="Docfixit"]Possible faulty struts have fronts and rears ever been replaced?[/quote:bc3741eb84]
No, none of that.
Mar 22, 2010 at 4:53 AM
DOCFIXIT
  • 18,828 POSTS
Be a good place to start looking worn struts cannot hold wheel to road and start to wheel hop ie. washboard
Mar 22, 2010 at 4:58 AM
OL2LRUS
  • 5 POSTS
[quote:07cbf00d14="Docfixit"]Be a good place to start looking worn struts cannot hold wheel to road and start to wheel hop ie. washboard[/quote:07cbf00d14]
Seems reasonable, touching the brakes would break the resonance. Someone also suggested the wheel bearings might be going. comment?
Mar 22, 2010 at 5:05 AM
DOCFIXIT
  • 18,828 POSTS
No if no noise present and bearings won't cause wheel hop
Mar 22, 2010 at 7:15 AM
OL2LRUS
  • 5 POSTS
Seems reasonable. This wheel hop you are talking about, can the vibration be pretty high? I mean, I've seen cars with wheel hop and the rate appears to be pretty low. This vibration was like hitting rumble strips at high speed. thanks...
Mar 22, 2010 at 9:16 AM
DOCFIXIT
  • 18,828 POSTS
A checking of suspension would answer question. Steering rack, tie rods could also but would be felt in steering wheel.
Mar 23, 2010 at 8:18 AM
OL2LRUS
  • 5 POSTS
Thanks, I'm on it.
Mar 23, 2010 at 12:05 PM
HAPPYMATTSLICE
any resolution to this issue? My '05 3.5 with manual transmission is doing this same exact thing. only at highway speeds, as soon as I get off the gas it goes away.
Dec 15, 2010 at 4:39 PM
