2005 Nissan Altima Rear hub asembly
ROBERT.A.BARNES
Drive Train Axles Bearings problem
2005 Nissan Altima 4 cyl Front Wheel Drive 75000 miles
I know how to replace this part,but i wanted to know the socket sizes to remove center nut in hub and the size for the four nuts which hold it in place, really my is this.Sizes for large middle hub nut and all other nuts that must be remove to remove hub assembly. thank you Spc. barnes,United States Army.
Apr 14, 2010 at 2:56 PM
KHLOW2008
  • 41,812 POSTS
Hi robert.a.barnes,
The 4 pcs of holding bolts are 14 mm hex bolt head.
The exact data are not available in our database and based on personal experience, Nissan uses either a 30 or 32 mm sized nut for the central spindle nut.
Apr 22, 2010 at 4:23 AM
