2005 Nissan Altima INSTUMENT CLUSTER AND CRUISE
2005 NISSAN ALTIMA
87,000 MILES • 6 CYL • FWD • AUTOMATIC
EBASSI
While driving today I looked at my speedometer and saw it was not working . The odometer and engine temp gauges were also not working. Upon further inspection discovered cruise and blinkers not operating. Also the check oil light and door ajar lights were lit. Car ran fine, radio ,lights and AC work. Car sat for 8 hours,started up and everthing was working. What should I do?
May 26, 2010 at 5:16 PM
2CARPRO JACK
  • 11,533 POSTS
Sounds like you may have a power relay or ignition feed that is intermittent.Things like this can only be found when they are acting up.Next time the gauges arent working, use a test light to check for power at the fuses in thefuse panel.If it is a feed issue,there wont be power at the dash fuses when you test it
May 28, 2010 at 7:42 AM
