2005 Nissan Altima front bearings
2005 NISSAN ALTIMA
ONE2GOOF
Drive Train Axles Bearings problem
2005 Nissan Altima 6 cyl Front Wheel Drive Automatic
how do i take off the rotor hubs to get to the bearings do i need a puller or are these just stubborn and i need to mess with them a bit more?
Thanks
Jul 5, 2010 at 1:04 AM
BLUELIGHTNIN6
  • 16,542 POSTS
to remove the wheel hub you have to separate the tie rod from teh steering knuckle using a special service tool #HT72520000 and then use a puller to separate the drive shaft from the knuckle.
Jul 5, 2010 at 8:44 AM
