2005 Nissan Altima Catalytic Converter
2005 NISSAN ALTIMA
230,000 MILES • 4 CYL • 2WD • AUTOMATIC
ISB68
I took my car to my local dealer for an unrelated problem and the service advisor told me that my "check engine light" was on, he checked it out and told me I needed a new catalytic ASAP or my engine will blow up very soon. That was about 20,000 miles ago. Today I took it to a transmision shop [again an urelated problem] and he told me the same thing and said he had two cars in his shop right now with blow engines due to stopped up cats.
Is this likley or even possible?
Mar 22, 2010 at 12:38 PM
CARADIODOC
  • 34,381 POSTS
The oxygen sensor in the exhaust system switches between rich and lean conditions very quickly, up to a few times per second. Since 1996, there has been a second O2 sensor after the catalytic converter. If the converter is working proprly, that second sensor will switch between rich and lean very slowly, perhaps many seconds between cycles. When the converter stops changing the exhaust gases into something harmless, the stuff going out is the same as the stuff going in. The second O2 sensor switches at the same faster rate as the front one. That's how the Engine Computer can tell when the converter isn't dong it's job. That alone should not damage the engine.
The converter can also become plugged from leaded fuel in the past, and from the catalyst melting today. Too much unburned fuel in the exhaust will overheat the converter and melt the porous material causing it to become plugged. The typical symptoms are very low engine power, engine overheating, an unusual hiss from the tail pipe, and possibly some popping out of the intake system. The engine will also have a tendency to idle unusually smoothly.
Before you have the converter replaced, the emissions system should be inspected and tested first. Many more problems are caused by the oxygen sensors than the converters.
caradiodoc
Mar 22, 2010 at 1:28 PM
JOEYJIMZ
  • 5 POSTS
[quote:641ed61ee5="caradiodoc"]The oxygen sensor in the exhaust system switches between rich and lean conditions very quickly, up to a few times per second. Since 1996, there has been a second O2 sensor after the catalytic converter. If the converter is working proprly, that second sensor will switch between rich and lean very slowly, perhaps many seconds between cycles. When the converter stops changing the exhaust gases into something harmless, the stuff going out is the same as the stuff going in. The second O2 sensor switches at the same faster rate as the front one. That's how the Engine Computer can tell when the converter isn't dong it's job. That alone should not damage the engine.
caradiodoc[/quote:641ed61ee5]
GOING THREW THE SAM SORT OF PROBLEM ABOUT EIGHT MONTHS AGO CAT PLUGED UP REPLACED NOW HAVE HAD ISSUE OF NO START FOUND CYLINDERS WITH WATER REPLACED HEAD GASKET BUT NOW CAT STILL GLOWING RED AFTER HEAD GASKET DONE
Mar 28, 2010 at 7:05 PM
CARADIODOC
  • 34,381 POSTS
Hi Joeyjimz. What's your thinking? Are you saying your head gasket now was caused by a plugged converter 8 months ago, or how are they related?
A glowing catalytic converter is a different problem with a different cause than what ISB68 has. Too much unburned fuel is the reason for the converter overheating. That will melt the catalyst and cause it to become plugged. If you have a '96 or newer car, the Check Engine light should be flashing. The excessive fuel can be caused by a single cylinder misfire, spark related, excessive fuel pressure, or an injector stuck open.
A plugged converter will not cause a head gasket to leak, at least not directly. If engine power is reduced, as you press harder and harder on the gas pedal, the engine works much harder to push the exhaust out. It starts to heat up like an air compressor. The higher engine temperature could cause parts to expand more than normal, (aluminum heads in particular), leading to a warped head or leaking gasket.
Since the head gasket was replaced, do you feel a misfire to go along with the red converter? The glowing should be addressed before the new converter melts inside. One thing that is often overlooked, especially when there is no noticeable misfire is an exhaust leak ahead of the front oxygen sensor. In between the pulses of exhaust gas, the momentum creates a pulse of small vacuum. Air will be drawn in through the leak, and the oxygen sensor will detect unburned oxygen. The Engine Computer will command the injectors to stay open longer to add fuel to go with the oxygen. No matter how much fuel is added, there will always be that unburned oxygen there so the computer keeps increasing the injector on-time as much as possible. You might smell raw fuel out of the tail pipe, but O2 sensors don't detect unburned fuel, just oxygen.
caradiodoc
Mar 28, 2010 at 8:48 PM
JOEYJIMZ
  • 5 POSTS
[quote:684dae0c3a="caradiodoc"]Hi Joeyjimz. What's your thinking? Are you saying your head gasket now was caused by a plugged converter 8 months ago, or how are they related?
A glowing catalytic converter is a different problem with a different cause than what ISB68 has. Too much unburned fuel is the reason for the converter overheating. That will melt the catalyst and cause it to become plugged. If you have a '96 or newer car, the Check Engine light should be flashing. The excessive fuel can be caused by a single cylinder misfire, spark related, excessive fuel pressure, or an injector stuck open. Here is the thing cardiodoc my cat was plugged normal syptoms loss of power glowing red so obviously i replaced it but i made the mistake of driving it for quite a wile after i finally replaced the cat i had to codes the first being p300 random missfire and the other being bank 1 sensor 2 high V. the problem of missifre progressed and had harder time starting and missfire at start up i first thought for some reason it was flooding with fuel due to the high v code on sensor 2 come to find out i have water in 2 cylinders 2 and 3 so now i have replaced the head gasket and cat was glowing i checked my 02 sensors and sensor 1 was dead totally lean causing sensor 2 to be rich witch makes sense of one code and the missfire code done with the head gasket being done. so i replaced sensor 1 and now have perfect cross counts and sensor 2 normal reading. wouldint that mean im not running rich any more? But cat is still glowing red. Besides the point i have a high idle could the high idle affect fuel mixture at all? I didnt think so but can it? im totally stumped and need help if you have any suggestions please reply i have also posted a question as coolant in 2 cylinders about 3 questions under this one. thanks
caradiodoc[/quote:684dae0c3a]
Mar 30, 2010 at 3:22 PM
JOEYJIMZ
  • 5 POSTS
Caradiodoc I do belive the leaking was cause by the cat but I do think it was the head that got warped not so much the gasket but why now after gasket replaced am I still getting a red cat? I replaeced 02 sensor 1 it was dead and reading lean with no cross count sensor 2 was rich after replacing cross count is normal from lean to rich but and sensor 2 normal but cat still glowing red im totally lost please help with any suggestions. MAF normal 1.7 and cat dont seem pluged do you think its possible that driving it for quite a wile with coolant in cylinders cause me to damage cat again but it seems to be working. also can high idle speed contribute to the red cat please hlep
Mar 30, 2010 at 3:30 PM
CARADIODOC
  • 34,381 POSTS
I'm not going to pretend to be a Nissan expert, but I can give you some generic suggestions. The only way a catalytic converter can get red hot is by burning too much unburned fuel. That will lead to a melted and plugged converter eventually. The question is why is there too much fuel?
The most common cause of too much fuel is because the Engine Computer thinks the mixture is too lean so it turns the injectors on for longer pulses. A misfiring cylinder due to loss of spark will allow unburned air and fuel to enter the exhaust stream. The oxygen sensor will detect the unburned oxygen and make the computer think there isn't enough fuel to go with it. O2 sensors don't detect unburned fuel. No matter how much extra fuel is commanded by the computer, there will still be that unburned oxygen. The unburned fuel from the misfiring cylinder, and the extra fuel from all the other cylinders burns in the converter.
A similar problem occurs if an injector isn't firing properly or is disconnected. There will be a bunch of unburned air entering the exhaust that is detected by the O2 sensor. The computer will increase the fuel from all of the other injectors. Now you have a bunch of fuel and air again that burns in the converter.
A much less obvious and hard to find problem is a leak in the exhaust system ahead of the O2 sensor. In between the pulses of exhaust flow, the momentum creates small pulses of vacuum. That vacuum draws in outside air that is detected by the O2 sensor. The computer increases fuel metering in an attempt to overcome the lean condition, but no matter how much extra fuel is delivered, the unburned air is still there.
A different but related problem can occur on cars with distributors. If the ignition timing is excessively retarded, the mixture will be ignited and start burning too late. It will still be burning when it is pushed out past the exhaust valve. This will be most visible on engines that have thin header-type exhaust manifolds. They will glow orange, but the burning is usually done before the mixture gets to the converter. Engine power will be low too.
On engines with a vacuum hose going to the fuel pressure regulator, a leaking or improperly connected hose will cause fuel pressure to go too high. That will force more fuel through the injectors than the computer is expecting. If that hose is allowing air in, you'll have extra fuel and extra air. Normally all the fuel burns in the engine, but idle speed will be too high.
As a rule, a problem with a single cylinder is usually the cause of too much fuel and air entering the converter. The clue is that idle speed is close to normal.
caradiodoc
Mar 30, 2010 at 6:05 PM
