2005 Nissan Altima Bizarre electrical problem
75,000 MILES • 6 CYL • 2WD • AUTOMATIC
WILLIAMS1308
I open my car door to get in and the interior lights, etc come on as normal. When I slide the key into the ignition, it will "ding" if the door is open. So far so good....but when I turn the key, everything turns off! The lights, the dinging noise the button that opens the trunk...everything stops working. No power to anything.
But then I can hit the dash or steering wheel and everything will turn back on (CDs will pop out of the CD player and the radio station presets and time are all reset).
I usually have to repeat this process a couple times before the car will start without everything turning off.
I'm assuming there has to be a short or something because the starter or battery wouldn't cause everything to just go dead, and then come back on when jarred would it?
Please help!
Jun 7, 2010 at 8:42 AM
2CARPRO JACK
  • 11,533 POSTS
Sounds like you may have an issue with the ignition switch.SInce this only occurs when the key is in theignition and not when youa re just int hecar, that is wheer I would start.If you remove thecolumn panels enough to get to the electrical part of the ignition (not the key tumbler) you can try tapping on it directly to see if you get a reaction
Jun 7, 2010 at 4:40 PM
