2005 Nissan Altima bad catalayic converter
STABONES
Engine Performance problem
2005 Nissan Altima 4 cyl Automatic 109,00 miles
what can i do to fix this? if i change o2 cenors will that help tech says i have 2 converters what do u suggest an can i drive it with a bad cat?
Jun 25, 2010 at 12:35 PM
BLUELIGHTNIN6
  • 16,542 POSTS
faulty oxygen sensors often lead to faulty cat. converters. the coverters should last lifetime of vehicle so when they fail there is normally a problem elsewhere causing it to fail..yes you can drive with a bad cat. coverter but it may affect fuel mileage and you can't pass smog tests if your state requires them.
Jun 25, 2010 at 12:39 PM
