2005 Nissan Altima a/c stop working blowing hot air.
103,509 MILES • 4 CYL • FWD • AUTOMATIC
PARKER7042
Was traveling when i pulled over to take a 2 hour nap and when i woke up and started the car and turn on the air conditioning it only blow out hot air instead of cold air. pressure and freon level is fine. please help!!!!!!!!
Jul 14, 2010 at 11:01 AM
  • 75,988 POSTS
Could be freezing up due to air and moisture forming into ice and blocking off the orifice or the air blend door is stuck in the heat position and the HVAC control module
Jul 14, 2010 at 11:34 AM
