Engine Mechanical problem
2005 Nissan Altima 4 cyl
Where is the crank shaft sensor
Feb 21, 2010 at 2:05 PM
BLUELIGHTNIN6
✓Experienced Mechanic
For the 2.5L engine, the crankshaft position sensor is located on the right rear of the cylinder block, below the starter .
On the 3.5L engine it will be found on the lower left rear of cylinder block.
Feb 21, 2010 at 2:12 PM
