2004 Nissan Altima Struts
99,000 MILES • 4 CYL • FWD • AUTOMATIC
KIMBER42
I was recently told by my mechanic that my struts should be replaced. What will happen if I do not replace them? Will there be further damage? I've gotten used to driving with them damaged...
Mar 24, 2009 at 3:34 PM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:05c1dab561="kimber42"]Suspension problem
2004 Nissan Altima 4 cyl Front Wheel Drive Automatic 99,000 miles
I was recently told by my mechanic that my struts should be replaced. What will happen if I do not replace them? Will there be further damage? I've gotten used to driving with them damaged...[/quote:05c1dab561]
Your vehicle will bounce more and you could loose control if bouncing gets real bad. You will wear the tire about 2 - 3 times faster.
Mar 24, 2009 at 3:54 PM
