Low idle when I am at a complete stop
88,000 MILES • 4 CYL • 2WD • AUTOMATIC
LBROCKMAN
When I come to a complete stop and my transmission is in drive my idle drops to almost 0 and feels like my car is going to stall. A few times it has, what is causing this problem?
May 8, 2008 at 7:49 AM
  • 75,988 POSTS
Could be an idle air control valve/throttle position sensor and EGR valve. This guide should help us
https://www.2carpros.com/articles/stall-at-idle
May 8, 2008 at 9:15 AM
LARRY THORNBRUGH
Engine Performance problem
1998 Nissan Altima 4 cyl Front Wheel Drive Automatic
the engine idles around 2000 rpm when cold, and when it is warmed up it idles around 900 to 1000 rpm. Is there any way i can adjust the idle down on this vehicle?
May 20, 2020 at 6:33 AM (Merged)
ARC_55
  • 66 POSTS
this seems to be fairly normal rpm for cold start and operating temperature idle. You might do more harm then good trying to tampering with the idle.
you can try cleaning the throttle body and iacv or even adjusting an idle screw if equipped but the idle speed is controlled by the ecm through the idle motor.
I would check ignition advance as high advance will raise idle speed. Also check for fuel pressure regulator leak.
BOISEMIKE
1993 nissan altima idles fast, doesn't accelerate well at low rpm's. what can I do?
  • 75,988 POSTS
Do you have a check engine light on?
Could be caused by one of the following below
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Knock sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it and keep testin
