2004 Nissan Altima crank shaft position sensor
56,000 MILES • 4 CYL • FWD • AUTOMATIC
OUR4BRATS04
does anyone know where the crank shaft position sensor is located. my check engine light came on ran test code came back p0335 and p0725.
cant seem to find the sensor.
also has anyone heard of this being a recall for nissan altima 2004?
Thanks for any input.
Dec 29, 2007 at 1:36 PM
BMRFIXIT
  • 19,053 POSTS
[quote:181d0fd9cc="our4brats04"]Engine problem
2004 Nissan Altima 4 cyl Front Wheel Drive Automatic 56,000 miles
Thanks for any input.[/quote:181d0fd9cc]
check with your local dealer
it is may be under a recall
Dec 29, 2007 at 1:54 PM
  • 75,988 POSTS
What liter engine 2.5l or 3.5
2.5 on right rear of cylinder block, below starter motor.
3.5 on lower left rear of cylinder block
Dec 29, 2007 at 2:00 PM
OUR4BRATS04
thank you will check it out tomorro and replace it i hope this is the problem. will keep it updated.
Dec 29, 2007 at 2:04 PM
