2003 Nissan Altima possible transmission problem?
CWMA76
  • 2003 NISSAN ALTIMA
Engine Performance problem
2003 Nissan Altima 4 cyl Front Wheel Drive Automatic
i just got a tune up done on my wifes car. We had been having problems with the car not starting and now there is a problem to where the car will not go more than 20 mph. Could this be a problem with the transmission?
Saturday, August 7th, 2010 AT 11:52 PM
  • 109,885 POSTS
Does it have any power up to 20? In neutral, can you rev it normally and does the engine sound normal?
Friday, August 20th, 2010 AT 9:57 PM
AB1975
  • 15 POSTS
If it revs normally in neutral but won't go when you put it into drive, it could potentially be the alternator as the battery likes to be continuously charged while running in order to go faster.
It "could" be a transmission problem. You didn't say how many miles were on the car. And you didn't mention if the gears were shifting on their own or if you're getting stuck in 1st gear?
Also, if it is an automatic transmission, can you start in 1st gear and manually change the gears? If it will do this, I then suggest having the transmission looked at. It could be the transmission computer, the shift solenoids could be clogged or could be a problem with the shift position switch.
I strongly suggest, if you do bring it to a mechanic, and they even suggest rebuilding the transmission, to have 3 or more transmission specialists take a look at it and give you estimates. There are mechanics out there that specialize in transmissions only.
Tuesday, October 12th, 2010 AT 1:50 PM
