2003 Nissan Altima oxygen sensr
2003 NISSAN ALTIMA
76,000 MILES • 6 CYL • 2WD • AUTOMATIC
ALFRED13
where is the oxygen sensor and hoe to replace it
Feb 20, 2008 at 9:11 AM
FISHERMAN
  • 937 POSTS
[quote:6b04bf0792="alfred13"]Engine Mechanical problem
2003 Nissan Altima 6 cyl Two Wheel Drive Automatic 76000 miles
where is the oxygen sensor and hoe to replace it[/quote:6b04bf0792]
Hello !!
Which oxigen sensor?
I believe there`s three O2 Sensors on the v-6 engine
One on each exhaust manifold and one after the catalytic converter..
Do you have a code out the ECM?
Which code is that?
let us know to guide you to the right path..
BTW thanks a lot for your donation!!
Feb 20, 2008 at 9:17 AM
FISHERMAN
  • 937 POSTS
Its me again... Ok in some cases it may be necessary to remove the heat shield to remove the oxigen sensors.. here is the picture of The heated O2 sensors: (bank 1 and bank 2)
https://images.2carpros.com/forum/automotive_pictures/576_00_4.jpg
good luck and let us know if you have any question!!
Feb 20, 2008 at 10:28 AM
