Engine light come on but goes away after either after shut off or acceleration.
also happend when engine was cold, warm but not at operation temp.
visible enging shake / vibration on idle
feehls like running on uneven cylinders
generaly with acceleration stops the problem.
the Crank shaft sensor was replaced @ ~80000 m.
This is adifferend problem as the car would not trun on even when @ operation temp.
Oct 23, 2010 at 3:42 AM
