2003 Nissan Altima DTC P0300
2003 NISSAN ALTIMA
BIGWIL32
  • 13 POSTS
2003 Nissan Altima
I have a P0300 code, could this be an indication of a bad O2 sensor if all of the coil packs are firing? I have verified all hoses, connections and fuel injectors.
Dec 3, 2008 at 6:54 AM
ZACKMAN
  • 4,202 POSTS
Do you have any other code(s) other than P0300? P0300 explained:::
P0300 Code - Cylinder Misfire
Technical Description
Random/Multiple Cylinder Misfire Detected
What does that mean?
Basically this means that the the car's computer has detected that not all of the engine's cylinders are firing properly.
A P0300 OBD code indicates a random or multiple misfire. If the last digit is a number other than zero, it corresponds to the cylinder number that is misfiring. A P0302 code, for example, would tell you cylinder number two is misfiring. Unfortunately, a P0300 doesn't tell you specifically which cylinder(s) is/are mis-firing, nor why.
Symptoms
Symptoms may include:
* the engine may be harder to start
* the engine may stumble / stumble, and/or hesitate
* other symptoms may also be present
Causes
A code P0300 may mean that one or more of the following has happened:
* Faulty spark plugs or wires
* Faulty coil (pack)
* Faulty oxygen sensor(s)
* Faulty fuel injector(s)
* Burned exhaust valve
* Faulty catalytic converter(s)
* Stuck/blocked EGR valve / passages
* Faulty camshaft position sensor
* Defective computer
Possible Solutions
If there are no symptoms, the simplest thing to do is to reset the code and see if it comes back.
If there are symptoms such as the engine is stumbling or hesitating, check all wiring and connectors that lead to the cylinders (i.e. spark plugs). Depending on how long the ignition components have been in the car, it may be a good idea to replace them as part of your regular maintenance schedule. I would suggest spark plugs, spark plug wires, distributor cap, and rotor (if applicable). Otherwise, check the coils (a.k.a. coil packs). In some cases, the catalytic converter has gone bad. If you smell rotten eggs in the exhaust, your cat converter needs to be replaced. I've also heard in other cases the problems were faulty fuel injectors.
Random misfires that jump around from one cylinder to another (read: P030x codes) also will set a P0300 code. The underlying cause is often a lean fuel condition, which may be due to a vacuum leak in the intake manifold or unmetered air getting past the airflow sensor, or an EGR valve that is stuck open.
Dec 4, 2008 at 2:09 PM
