I'd like to know in a nissan altima if the timing chain was put on wrong diagram could it affect the valves
Wednesday, October 13th, 2010 AT 10:12 PM
BLUELIGHTNIN6
MECHANIC
Very possible that valve(s) were damaged with the timing chain incorrectly installed, yes.
SPONSORED LINKS
Wednesday, October 13th, 2010 AT 10:21 PM
LEMAX1975
MEMBER
1 POST
Well I guess I had to remove the head and send it to the shop to get corrected and put it back with the right diagram cause i'm about to buy the car but I know it running bad the engine is shaking a little bit when you shut it down you ca hear the air leaking out of the valve.
Thursday, October 14th, 2010 AT 5:57 PM
KHLOW2008
MECHANIC
Before removing the head, recheck the valve timing first.
If the air filter had been replaced with a fast flow type, it would occur as mentioned. So would a removed or bad filter.
