2002 Nissan Altima Ticking noise
2002 NISSAN ALTIMA
70,000 MILES • 4 CYL • 2WD • AUTOMATIC
RONDHOL
I hear loud ticking/taping noise when the engine is cold (40F) and under load. That noise is gone after it's warm. I am using full synthetic oil 5w-30.
The engine runs very smooth at 50mph without any audible noise. But the light ticking noise can be heard at idle.
Is very light raspy noise at 1500-2000 rpm caused by bad flex exhaust pipe in front of the catalytic converter?
Dec 25, 2008 at 1:09 AM
BUDDYCRAIGG
  • 2,262 POSTS
have you had the upper cam chain guide removed yet?
you need to have that done.
Dec 25, 2008 at 3:01 AM
RONDHOL
What is cam chain guide? Can I see it by removing valve cover? The pre-cat is new and the flex pipe is fine. The ticking noise (like computer hard drive) occurs after 10 minutes driving at very light load (1500-1800 rpm). Higher rpm or lower rpm give no noise. No problem at neutral.
Feb 26, 2009 at 12:32 AM
BUDDYCRAIGG
  • 2,262 POSTS
Sounds are hard to diagnose over the internet.
The tone and the frequency at various RPMs may mean something to a trained ear. But trying to explain it via text is going to be hard to get across.
Mar 2, 2009 at 7:36 PM
RONDHOL
I can say,The ticking frequency is like loud computer harddrive noise after start up. The noise is only at 1500 rpm (drive/reverse only) for any speeds and gears after fully warm up. When the engine is cold, there is almost no noise.
Mar 2, 2009 at 7:42 PM
