2002 Nissan Altima starts then idles rough
96,000 MILES • 4 CYL • FWD • AUTOMATIC
TGBARON
Hi, once in awhile when you start the engine it will idle rough untill you step on the throttle then it runs fine, any ideas will help THANKS.
Jan 17, 2010 at 2:57 AM
MERLIN2021
  • 17,250 POSTS
There is a recall for three sensors and a tech bulliten for performing an idle relearn proceedure, unfortunatly the relearn requires a Consult II Nissan scantool to do, so a trip to the dealer is in order. I will email both documents to you.
Jan 17, 2010 at 3:19 AM
TGBARON
Thank you very much for your speedy response ! I will contact the dealer and see if i can get this resolved. THANK YOU
Jan 17, 2010 at 5:14 AM
MERLIN2021
  • 17,250 POSTS
You bet.
Jan 17, 2010 at 6:25 AM
