2002 Nissan Altima smoking and losing water
2002 NISSAN ALTIMA
CUBS36613
Engine Cooling problem
2002 Nissan Altima 4 cyl Wheel Drive Type unknown Automatic 103000 miles
have a 2002 altima that has white smoke that comes out of the exhaust right after it is started up and then for about a minute while i am driving and then stops.does not do it all the time. also it is losing coolant a couple times during the week. not over heating but the tempature jumps back and forth between normal and hot.
Mar 16, 2008 at 11:09 AM
SERVICE WRITER
  • 9,123 POSTS
You don't want to keep driving like this or it will get expensive. Coolant is getting into the combustion chamber possibily from a headgasket leak.
Continued driving like this can cause serious internal engine damage, damage to the cat converter as well.
There are various ways of checking this in you want to ge down that path. If not and deal with a shop normally then get it in there ASAP.
Mar 16, 2008 at 11:10 AM
BMRFIXIT
  • 19,053 POSTS
I suggest having a head gasket test
Mar 16, 2008 at 11:13 AM
