2002 Nissan Altima Hi There
SEDERLIN
2002 Nissan Altima 4 cyl Two Wheel Drive Manual
my clutch is sticking to the floor what is the problem?
Feb 12, 2010 at 12:58 PM
  • 31,937 POSTS
Hi there,
You will have lost the clutch hydraulic fluid due to a leak at the master Cly or the slave cylinder, look under the rubber boot on the slave Cly (on the gear box at the clutch) if wet this will need replacing, also check under the dash on the fire wall where the clutch pedal is, if there is fluid running down the body work the master cylinder has failed, you can get the clutch working temporary by adding fluid to the system and bleeding the air out at the slave.
Mark (mhpautos)
Feb 12, 2010 at 2:41 PM
