headlight wiring diagrams please?
2002 NISSAN ALTIMA
11,000 MILES • 4 CYL • 2WD • AUTOMATIC
STREETSERVANT
  • 6 POSTS
The headlights on my altima have started going on and off and do not stop. What is causing this and how do I fix it? Thanks
Aug 15, 2008 at 2:53 PM
SERVICE WRITER
  • 9,123 POSTS
Does it happen when the vehicle is not running?
Do you have an anti-theft system..factory or aftermarket?
Is it a random blinking or a steady consistent flashing?
Aug 16, 2008 at 12:22 AM
STREETSERVANT
  • 6 POSTS
The vehicle is rebuilt, there is no alarm system. Both lights flash on and off when the car is running. It started when the lights where on auto, turning them on manually they stopped flashing for a short time then both started flashing again.
Aug 16, 2008 at 2:08 AM
SERVICE WRITER
  • 9,123 POSTS
does it have Daytime running lights? Rebuilt huh? Need to find where the pulse is coming from with a test light. Here are the headlight wiring diagrams and a guide to help you test the wiring
Aug 16, 2008 at 2:45 AM
STREETSERVANT
  • 6 POSTS
It does not have daytime running lights. When it became dark last night the flashing stopped. They are not flashing today.
Aug 16, 2008 at 5:42 AM
SERVICE WRITER
  • 9,123 POSTS
Hmmm...just drive it in the dark. ;-)
IF it continues, I'll get the other diagram. Surprised it doesn't especially based on the new info...although, the darkness probably has nothing to do with it, since it is happening in the daylight.
Aug 16, 2008 at 8:37 AM
STREETSERVANT
  • 6 POSTS
So do you think this caused by a relay problem or a wiring problem on headlight control arm?
Aug 16, 2008 at 12:50 PM
SERVICE WRITER
  • 9,123 POSTS
Anything is possible with a rebuilt situation.
You want to assume that everything was done right....but...
I'm thinking a relay. I'm not the greatest electrical guy by far though. Either the system is is controlled by the ground being interupted or the power being interupted for it to flash. Since it is a consitent type of flash it makes me think internal problem with a relay Do you want the other diagram? IF so, do you want it emailed? You can send a PM with your address to me if you do.
Aug 17, 2008 at 1:42 AM
STREETSERVANT
  • 6 POSTS
You can e-mail that to me. I will probably check the relay first. Thanks for all your help. I'll definetly use you again. Mike
Aug 17, 2008 at 10:46 AM
SIERVO INUTIL
Service Writer could you please send the diagram to me?
Sep 12, 2020 at 2:31 PM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
You have attached to a question that is years old.What we ask you to do is start a new question and be sure to include all your vehicle information.Here is the link:
Hope this helps and we will be looking for your question.Thanks for using 2CarPros.
Sep 13, 2020 at 7:06 AM
