2002 Nissan Altima Glove Compartment
137,000 MILES • 6 CYL • 2WD • AUTOMATIC
DANURSE
My glove compartment is stuck and the latch simply moves back and forth with no resistance as if a springing mechanism is displaced. The key seems to make no difference. How can I get it open/fix it without bringing a crowbar into the picture?
Oct 23, 2008 at 6:39 PM
IMPALASS
  • 3,112 POSTS
Hello
This is a tough question as the information I am looking at doesn’t show all the details probably necessary. Are you able to take a couple of pics of this to attach? I show this on the center console…….is this correct? If you are unable to then I will resend this back to some of the other moderators to see what else we can come up with.
Hope this helps – let us know – Thanks for asking on our site!
Oct 24, 2008 at 4:31 AM
KHLOW2008
  • 41,812 POSTS
Hi Danurse,
The latch lever inside is most probably broken or dislodged. The only way to open it is to try to unlatch it by using a screw driver into the latch hole from beneath. Try to get to the unlocking tab and push it to unlock. You might need a bent rod instead of a screwdriver.
Oct 24, 2008 at 4:35 AM
