2002 Nissan Altima Engine seems to 'strain' during freeway
10,500 MILES • 4 CYL • 4WD • AUTOMATIC
MAVERICK74
Hi, wondering what the problem is with my engine
Overall the car seems to have less 'guts', and it seems as if I have to push the gas pedal in farther to get it to go. At freeway speeds I hear a louder, almost whirring noise and the car seems as if it's not shifting into 5th. Any ideas what the cause might be?
Thanks very much.
Jun 4, 2010 at 11:07 AM
  • 75,988 POSTS
Lack of acceleration,chugging,hesitating,bogging etc. could be caused by one of the following below.
Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Jun 4, 2010 at 11:26 AM
