2002 Nissan Altima cyn
2002 NISSAN ALTIMA
94,000 MILES • 4 CYL • FWD • AUTOMATIC
CYNTHOMAS
i have an exhaust leak and my check engine light is on, also my oil light keeps going off and on. how can i fix this with out going to the repair shop? the noise is getting louder and the car is pulling when accelerating it. please help me.
Nov 12, 2008 at 1:15 AM
ZACKMAN
  • 4,202 POSTS
Depending on what the leak is. If it is a gasket leak, you can probably repair it yourself. If it is a hole on the exhaust pipe, and you know how to weld, you can probably fix it your self. But if you can't do either, I don't see how it can be fixed without going to a shop.
The check engine light is probably due to the exhaust leak, so there is nothing you can do until you fix the exhaust.
As for the oil light flickering, first make sure that you actually have enough oil in the engine. Next, make sure that your oil sending unit is working properly. If not, replace the sending unit.
Nov 12, 2008 at 2:59 PM
