Serpentine Belt Replacement
LILLIE
  • 5 POSTS
How do you replace the serpentine belt. I need a belt routing diagram. Please help me I need it and I love this site!
Nov 26, 2007 at 11:07 AM
  • 55,649 POSTS
Here is a page that has the diagram you are looking for
https://www.2carpros.com/diagrams/nissan/altima/2002
Here is a guide on how to change the belt
https://www.2carpros.com/articles/replace-serpentine-belt
Here is a diagram on the serpentine belt replacement you asked for (below) I have included both engines in case someone needs them.
Cheers, Ken
Nov 9, 2017 at 9:33 AM
SOTO8081
My belt keeps popping off.
Nov 9, 2017 at 9:33 AM (Merged)
  • 31,937 POSTS
Does the belt have an automatic tensioner? is it tight? is it the correct length belt? check for worn pulley bearings, often it is a misaligned pulley or a pulley running askew due to a badly worn bearing that causes the belts to come off.
JDRAGER
What type of Serpentine Belt do I need to buy for my 2005 Nissan Altima 2.5S? I've been looking on sites like Autozone.com, etc.
Thanks!
  • 110,248 POSTS
There is only one type that will work. When you go to get it, they will need the year, model, engine size, and if it has AC.
LESLIEAHOLA
best belt-i HAVE AN ACCT. WITH NAPA, LIFETIME replacement, $27.00
HMAC300
  • 48,601 POSTS
replace the tensioner as well they wear too
BUTTER32
Shakes or Wobbles problem
2005 Nissan Altima 4 cyl Front Wheel Drive Automatic 91000 miles
I wanted to know what causes the serpentine belt to shake or wobble when the a/c is turned on when the car is drive or reverse at low rpm's and at higher rpm's goes away?
ZACKMAN
  • 4,202 POSTS
Three things come to mind.
1. Faulty harmonic balancer
2. Bad passenger side engine mount
3. Serpentine belt too loose.
CDEMOTT
Warranty problem
1997 Nissan Altima 4 cyl Automatic 160000 miles
One of my parents as agreed to get me a car. My step-parent on the other side believes Im being given a cheap piece of junk. The pictures look good, no exterior damage, also its getting a new serpentine belt, alternater, valve cover and alarm system before I recieve it. However it has 160,000 miles. My step-parents argument is that a car with that many miles is going to constantly break down, is that true? Or am I getting a deceant car?
Nov 9, 2017 at 9:34 AM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
Without knowing the history of the car that is really hard to answer. The best thing to do is get a vehicle history report for the car. If there are ANY faults with it (previous wrecks, odometer fraud etc...) then stay away from buying it. If the history report is good then have a local repair shop do a small check on the car. If no major faults are found then go for it. If faults are found that require pricey repairs than find another car to buy.
AMORA
just an fyi...
I have this car and with regular minor maintenance it's been problem free for 12+ years...knock on wood.
