2001 Nissan Altima RADIATOR FUN
200,000 MILES • 4 CYL • FWD • AUTOMATIC
VERSEAUX1966
THE RADIATOR FUN STAYS ON ALL THE TIME WHILE I'M DRIVING.THE ENGINE TEMPERATURE IS NORMAL. I'VE CHANGED THE COOLING TEMPERATURE SENSOR AND THE ENGINE TEMPERATURE SENSOR AND ALSO THE THERMOSTAT. THE PROBLEM IS STILL THE SAME. DOES THE CAR HAS A FUN SWITCH AND CAN IT BE THE CAUSE. WHERE IS IT LOCATED. THANKS
Apr 4, 2008 at 6:21 AM
  • 75,988 POSTS
If its not coming from the fan relays -then it has to do with the computer controlled of the relays-
Apr 4, 2008 at 10:19 AM
