2001 Nissan Altima P0740
2001 NISSAN ALTIMA
95,000 MILES • 4 CYL • 2WD • AUTOMATIC
NASCARMIKE23
1 year ago when weather got colder, retreived code P0740 trans code. Trans has good fluid,no slip,shifts well. I am not sure if it maybe solenoid? or if it is difficult/worth fixing. Don't plan to keep car that much longer.
Mar 14, 2009 at 1:30 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello
Thanks for the donation.
DTC P0740 indicates TCC (Torque Converter Clutch) solenoid valve failure. Need to inspect your wiring to the TCC solenoid valve. If it is OK then suspect faulty TCC solenoid valve.
Thanks for using 2CarPros.com!
Mar 14, 2009 at 2:14 PM
