2001 Nissan Altima BAD OIL PRESSURE
2001 NISSAN ALTIMA
77,000 MILES • 4 CYL • 4WD • AUTOMATIC
GREATHORN
Hi,i have been having a problem with the oil light of my car. It has been on for a year but i have driven 7000 miles with out doing anything. Now that im on vacation, i changed the oil pump, oil pressure switch, oil filter, and new oil, and the wthe date my mechanic gave me the car back, the light was off, but the next day i started the engine and the oil light was on again. I drove it for a while and now the engine is making a weird noise. Plase help me
Jun 18, 2008 at 10:41 AM
Did you actually checked the oil pressure when you installed the new oil pump and also prime it before start-up The noise could be coming from the engine bearings such as crank/rod and cam-bearings.
Jun 18, 2008 at 12:01 PM
GREATHORN
well i did not check the oil pressure, and the mechanic told me that maybe there is an "internal bledding" where the pressure must be going away. I dont know if i should trust him or not.
Jun 18, 2008 at 5:16 PM
Get the oil pressure recheck and comeback with the readings.
Jun 19, 2008 at 8:45 AM
