the car has automatic windows and the drivers side won't roll up now that it has been rolled down. where should I start checking?
Jun 12, 2008 at 8:57 AM
MASTERTECHTIM
✓Experienced Mechanic
check for power and ground at the window motor. you will need to remove the door panel, if you have power and ground across the connector when switched up then the motor is bad
