2000 Nissan Altima Water Pump or Thermostat Issue
2000 NISSAN ALTIMA
112,500 MILES • 4 CYL • FWD • AUTOMATIC
MKLING
  • 8 POSTS
I have what appears to be moisture below the thermostat housing but with the engine running I see nothing. While idling I hear a very high pitched noise/squeek from the belt side of the engine. Sometimes its louder than other times. When I accelerate it goes away. In August Nissan replaced the idler pulley. Could it be that? From this can you suggest a diagnosis please?
Feb 20, 2008 at 11:27 AM
BMRFIXIT
  • 19,053 POSTS
[quote:529ce74cb9="mkling"]2000 Nissan Altima 4 cyl Front Wheel Drive Automatic 112500 miles
I have what appears to be moisture below the thermostat housing but with the engine running I see nothing. While idling I hear a very high pitched noise/squeek from the belt side of the engine. Sometimes its louder than other times. When I accelerate it goes away. In August Nissan replaced the idler pulley. Could it be that? From this can you suggest a diagnosis please?[/quote:529ce74cb9]
check belts
it may need to be adjusted
change thermostat and gasket
good luck
Feb 20, 2008 at 11:34 AM
MKLING
  • 8 POSTS
[quote:f8c1efd06a="BMRFIXIT"][/quote:f8c1efd06a]
check belts
good luck
Thank you. It was the belts. I will be changing the thermostat and gasket this weekend.
Feb 28, 2008 at 1:14 AM
