2000 Nissan Altima Vibration
AMARANNA
  • 15 POSTS
2000 Nissan Altima
I have a 2000 Nissan Altima GXE - when i apply brakes the steering wheel vibrates.i changed all the 4 tires,did wheel alignment and wheel balance 3 weeks before, no change. Pls advice
Oct 10, 2008 at 10:20 AM
ZACKMAN
  • 4,202 POSTS
Have your front brake check. That vibration comes from warped rotor(s).
Oct 10, 2008 at 9:55 PM
AMARANNA
  • 15 POSTS
i did the Brake inspection 2 times @ tires plus and they did not tell me any issues on the brakes,but instead they asked me change the struts and mounts.Pls advice.
Oct 11, 2008 at 6:29 AM
ZACKMAN
  • 4,202 POSTS
If it is a strut/strut mount issue, you will have the vibration all the times. If it is engine/trans mount issue, you will feel the vibration at idle, and more during hard acceleration or deceleration.
But you felt it as you applied the brake. I still stand by my initial diagnosis. When was the last time that the brake system checked? I am not talking checking the pads, I mean someone actually pulls the brake rotors out, measure the disc thickness and put them on a brake lathe machine to determine warpage.
Oct 11, 2008 at 10:19 AM
