2000 Nissan Altima Oil light comes on when at idle
90,000 MILES • 4 CYL • 2WD • AUTOMATIC
ANCAR56
Oil Light comes on when car is at idle .. Below 1000 rpm. Goes off when above , no rough drive no metallic noise from engine... Can it be either oil pump going bad or Oil sending unit switch faulty????
Sep 22, 2008 at 12:57 PM
  • 75,988 POSTS
Do an oil pressure check with a mechanical gauge if you found normal readings, you've located a bad oil pressure switch.
Sep 22, 2008 at 1:11 PM
