New Struts caused a vibration?
156,000 MILES • 4 CYL • FWD • AUTOMATIC
BRITTONP83
  • 7 POSTS
Hey guys,
This weekend I replaced all four struts on my girlfriends Altima. I followed the procedure and torqued everything to spec. but while working on the front drivers side I accidently dislocated the cv axle from the back of the hub assembly. It simply pulled apart at the boot, letting the spined axle come free. I matched up the spines as best I could and pushed the rotor/hub assemply back onto the shaft. After finishing the other struts with no issues, we noticed a vibration at highways speeds. She's taking it in for an alignment and wheel balance today but I'm worried that the vibration is due to me not "pressing" the axle back into the backside of the hub assembly. Could this be a simple fix?
Mar 9, 2010 at 2:14 AM
MATHIASO
  • 1,209 POSTS
Hello Brittonp83
It's possible that the vibration issue you're experiencing is related to the CV axle not being properly seated in the hub assembly. When the axle is dislocated and not properly aligned, it can cause vibrations during driving.
Mar 9, 2010 at 3:04 AM
BRITTONP83
  • 7 POSTS
Sorry it took so long for a response, but yes the alignment and balance fixed it. Thanks.
Jan 6, 2011 at 10:28 AM
BMRFIXIT
  • 19,053 POSTS
thank you for the update
Feb 9, 2011 at 7:01 PM
DANIELBENJAMIN
This is awesome and Web design services in UK very useful information! Thanks
Jun 8, 2023 at 11:24 PM
