HERE'S MY PROBLEM, I LOCKED MY KEYS IN THE CAR.SO I USED A SLIM JIM TO OPEN THE DOOR, NOW THE KEY WILL NOT UNLOCK THE DOOR FROM THE OUTSIDE. THE AUTOMATIC DOOR LOCKS WORK FROM THE INSIDE. SO I TOOK OFF THE DOOR PANEL, IT SEEMS THAT THERE IS A METAL BAR THAT IS NOT ATTACHED TO ANYTHING AT ONE END, AND THE OTHER END IS ATTACHED TO THE KEY LOCK.
WHERE DO I RECONNECT THE OTHER END SO THE KEY LOCK WILL WORK AGAIN.[/b]
Feb 19, 2006 at 4:49 AM
