Drain the cooling system.
Remove or disconnect the following:
Negative battery cable
Right lower splash cover
Alternator and A/C compressor
Coolant tube
Water pump
NOTE
Do not disconnect the air conditioning compressor lines. Unbolt the compressor and lay it off to the side. NOTE
The mounting bolts are different sizes and must be reinstalled in the correct location; therefore it is a good idea to arrange the bolts so that they can be easily identified during installation.
To install:
Be sure all gasket surfaces are clean and properly apply a continuous bead of silicone sealer to the pump.
Install or connect the following:
Water pump and torque the 6mm bolts to 57-66 inch lbs. (6-8 Nm) and the 8mm bolts to 12-14 ft. Lbs. (16-19 Nm)
Coolant tube
Right side lower splash shield
Fill the cooling system.
Start the engine, check for leaks and repair if necessary.
If you need further assistance just let me know.
Thanks for using 2CarPros. Com!
Monday, February 16th, 2009 AT 8:55 PM
