Noises problem
2000 Nissan Altima 4 cyl Two Wheel Drive Automatic
2000 Altima - 70,000 miles - work done
- thermister changed - harmonic stabilzer changed, brake booster changed -
I have 2 issues - one when I drive more than 30 miles - the temperature gauge goes up and done - I figure a bad sensor but does it cause the engine to not run smooth - only occurs after 30ish miles on the road. 2nd I had the brake booster go down about 6 months ago - it was changed but occassionally at very low speeds (less than 5mph) I hear a grinding sound from the front when I step on the brake - I took it to the brake serivice - they inspected all the brakes and did not find anything wrong with them.
May 17, 2008 at 5:34 PM
