1999 Nissan Altima power antenna
107,678 MILES • 4 CYL • 2WD • AUTOMATIC
SHAUNALAN
I just need to know how to remove this unit. I have removed the 2 screws that hold the unit on the frame, but how do you remove the antenna from the rear fender?
Jul 13, 2008 at 5:17 AM
KHLOW2008
  • 41,812 POSTS
Hi shaunalan,
You need to remove the chrome/blacck outer nut from the antenna. There is a slot across the nut, ues them as the disconnecting point with a long nose or circlip plier to unscrew it and you can get the antenna out.
Jul 18, 2008 at 1:58 AM
